wind restrictor
I was given a 986 wind restrictor from a friend.It has no hardware with it, How can I use it?
Rubber molding?
1999 Carrera2 tip arena red 2000 Boxster S tip...arena red ....black 1981 911sc targa...grey mkt.import...Rosewood 1978 911SC, guards red sunroof delete .much missed 73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead. |
You can buy the hardware kit to attach to the rollbar. Part # 986-561-323-00
Is there drilling involved? Iask because l cant use my drill hand problrm
There are three brackets to fit. The two upper brackets have two holes, but only one hole was predrilled in the roll bar in my 2004. You could probably leave it and get by with just one. The brackets are riveted in place, so you do need a pop riveter.
thanks, my pop riveter left with my Airstream, where it was well used Ive seen brackets for sale
good info, thx.Being partially disabled sucks in these situations
I found the 2 latches, left and right. What else is needed ?
Sent from my SM-G991U1 using Tapatalk
![]() https://www.pelicanparts.com/More_Info/98656132300.htm?pn=986-561-323-00-OEM Last edited by Randy328; 12-08-2022 at 07:57 PM.. |
