-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Timing chain rattle (http://forums.pelicanparts.com/boxster-cayman-forum/1130525-timing-chain-rattle.html)
Bellehayes 11-25-2022 11:30 PM
Timing chain rattle
Hi All
My 2000 model Boxster S manual with 205,000km has a timing chain rattle on start-up.
The effect was minimized when I was recommended to use Ravenol 10W50 HVE which virtually eliminated the problem.
At the last service, the garage filled up with Motul 10W40, and the problem came back.
However, if I let the oil level drop by 400ml, the rattle virtually disappears!
Any suggestions why this is happening and is it a common problem?
I live in Cape Town RSA so no cold weather issues here.
jlong 12-21-2022 07:58 AM
Timing chain rattle can be a function of weak chain tensioners (wearing out or not getting the proper oil pressure) or a worn-out chain (one that cannot be tensioned enough). I don't think oil type or oil level is going to solve this one for you long-term. The timing chain and tensioners system needs to be examined.
Do you have any other drivability issues? Are there any fault codes?
jluetjen 12-26-2022 11:54 AM
Are you sure that it's not just the valve lifters prior to them filling up with oil?
Jeff Alton 12-26-2022 07:34 PM
Correct, likely lifters.
have you had the camshaft deviation values read out with a scan tool?
Cheers
Turd 02-06-2023 09:04 AM
Cheers
My 2001 boxster s has made that rattle since I bought it in 2011 with 64,000 km. on it. 10 years later at 105,000 km I have quit worrying about it. Foolishly maybe but heck I still have the original IMS bearing too! The car runs like a top!
ASD 04-17-2023 10:59 AM
im in the og ims club too, but my 00 986S only has 76000 miles.
Litesonic 05-20-2023 06:01 PM
97 986 here...
Previous owner was scared and replaced the IMS. But hey, I got a new clutch out of his fear... so all is well.
Mine definitely makes more noise when I wake her from hibernation than when we are on an ice cream run in the summer.
YMMV.
61K miles.
