Timing chain rattle
Hi All
My 2000 model Boxster S manual with 205,000km has a timing chain rattle on start-up. The effect was minimized when I was recommended to use Ravenol 10W50 HVE which virtually eliminated the problem. At the last service, the garage filled up with Motul 10W40, and the problem came back. However, if I let the oil level drop by 400ml, the rattle virtually disappears! Any suggestions why this is happening and is it a common problem? I live in Cape Town RSA so no cold weather issues here. |
Timing chain rattle can be a function of weak chain tensioners (wearing out or not getting the proper oil pressure) or a worn-out chain (one that cannot be tensioned enough). I don't think oil type or oil level is going to solve this one for you long-term. The timing chain and tensioners system needs to be examined.
Do you have any other drivability issues? Are there any fault codes? |
Are you sure that it's not just the valve lifters prior to them filling up with oil?
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Correct, likely lifters.
have you had the camshaft deviation values read out with a scan tool? Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
My 2001 boxster s has made that rattle since I bought it in 2011 with 64,000 km. on it. 10 years later at 105,000 km I have quit worrying about it. Foolishly maybe but heck I still have the original IMS bearing too! The car runs like a top!
im in the og ims club too, but my 00 986S only has 76000 miles.
1999 Carrera2 tip arena red 2000 Boxster S tip...arena red ....black 1981 911sc targa...grey mkt.import...Rosewood 1978 911SC, guards red sunroof delete .much missed 73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead. |
Going faster all the time
97 986 here...
Previous owner was scared and replaced the IMS. But hey, I got a new clutch out of his fear... so all is well. Mine definitely makes more noise when I wake her from hibernation than when we are on an ice cream run in the summer. YMMV. 61K miles.
Now: 1997 German-built Boxster - Black Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray |
