ASD ASD is offline
ASD's Avatar
wind restrictor
I was given a 986 wind restrictor from a friend.It has no hardware with it, How can I use it?
Rubber molding?
1999 Carrera2 tip arena red
2000 Boxster S tip...arena red ....black
1981 911sc targa...grey mkt.import...Rosewood
1978 911SC, guards red sunroof delete .much missed
73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead.
Old 11-23-2022, 04:53 AM
Randy328's Avatar
You can buy the hardware kit to attach to the rollbar. Part # 986-561-323-00
Old 11-23-2022, 08:34 AM
ASD ASD is offline
ASD's Avatar
Is there drilling involved? Iask because l cant use my drill hand problrm
Old 11-23-2022, 01:21 PM
Randy328's Avatar
There are three brackets to fit. The two upper brackets have two holes, but only one hole was predrilled in the roll bar in my 2004. You could probably leave it and get by with just one. The brackets are riveted in place, so you do need a pop riveter.
Old 11-23-2022, 06:43 PM
ASD ASD is offline
ASD's Avatar
thanks, my pop riveter left with my Airstream, where it was well used Ive seen brackets for sale
Old 11-25-2022, 01:46 PM
ASD ASD is offline
ASD's Avatar
good info, thx.Being partially disabled sucks in these situations
Old 11-25-2022, 01:48 PM
ASD ASD is offline
ASD's Avatar
I found the 2 latches, left and right. What else is needed ?
Sent from my SM-G991U1 using Tapatalk
Old 12-05-2022, 07:23 AM
Randy328's Avatar
There is a third small bracket (middle one in the pic below) that must be attached to the bottom of the roll bar. The wind deflector base fits into it then clicks into the two latches at the top of the roll bar.
https://www.pelicanparts.com/More_Info/98656132300.htm?pn=986-561-323-00-OEM
Old 12-08-2022, 06:54 PM
