gumba's Avatar
5 point seat belts
I'm interested in installing 5 pt. seat belts in my Boxster. What are the shoulder belts attached to? Are there any after market vendors that make this set up.
Old 06-17-2003, 06:57 PM
Custom User Title
ettsn's Avatar
The shoulder belts can attach to the factory rollbar if you remove the plastic grill from the hoop. The side belts should attach to the factory belt points or the seat frame, and for the anti-sub, you'll need to either drill an appropriate mount in the floor or use a Y-belt to your two front seat bolts. HTH.
-Paul
Old 06-20-2003, 03:01 PM
