Stalls at Junctions when hot - wont idle.
986 Box 2.7 Year 2000 E-gas throttle
As soon as the car gets to running temperature, when you stop for any reason the revs die and the engine stalls. It will restart ok with a very rough idle (400 - 500 rpm) Could this be a fuel pump/ fuel pump relay issue? It bombs along on the highway ok, but a foot off and de-clutch, the revs drop and the motor stalls. Plug in the magic box - no fault codes show. HELP! John Davie ....Huntingdon UK |
Are you running your AC as well? I have this issue when I have the AC running. If I turn off the AC, no problem. There is obviously a power drain with the AC unit that I haven't bothered to investigate.
clean your throttle body, clean the MAF sensor, look for vacuum leaks.
| All times are GMT -8. The time now is 07:42 PM. |
