Stalls at Junctions when hot - wont idle.
986 Box 2.7 Year 2000 E-gas throttle
As soon as the car gets to running temperature, when you stop for any reason the revs die and the engine stalls.
It will restart ok with a very rough idle (400 - 500 rpm)
Could this be a fuel pump/ fuel pump relay issue?
It bombs along on the highway ok, but a foot off and de-clutch, the revs drop and the motor stalls.
Plug in the magic box - no fault codes show. HELP!
John Davie ....Huntingdon UK
Old 01-05-2024, 07:08 AM
WoodmanOGca's Avatar
Are you running your AC as well? I have this issue when I have the AC running. If I turn off the AC, no problem. There is obviously a power drain with the AC unit that I haven't bothered to investigate.
Old 02-22-2024, 05:47 AM
clean your throttle body, clean the MAF sensor, look for vacuum leaks.
Old 02-22-2024, 08:08 AM
