window problem
Hi, My driver's window drops when I open the door. But it does not work with the switch. I am wondering if one of the micro switches may be bad. Any thoughts on how to troubleshoot this problem would be appreciated. Which micro switches might cause this problem. The passenger window works without a problem. Given that the drop mechanism works, I assume the motor is not the problem? Thoughts. Thanks!
Why would you not suspect the driver side window switch? Switch the switches and see if the inoperative moves to the other side.
Sent from my SM-S928U using Tapatalk |
My driver side window switch stopped working also... and replaced with a used set, now it works
Similar window drop issue
My driver's side window will drop correctly but after the door is open the window will go back up 1/2 of the time. The original switch is good and the new installed switch is good. Thought that was the issue but apparently not. Any thoughts? How to check wiring??
| All times are GMT -8. The time now is 09:40 AM. |
