| Abijawara |
12-01-2024 04:19 PM |
A 2007 Cayman with 58K miles and a new clutch and flywheel sounds like a solid option, especially at $25K, but there are a few things you should be mindful of before moving forward.
First, the fact that the car has had several owners could mean different things—sometimes it’s just a result of a well-loved car changing hands, but it’s worth checking for any patterns in the history, such as frequent repairs or accidents. The large mileage jump in one year (10K miles) might indicate it was used as a daily driver or possibly for long road trips, so it's important to look for signs of heavy use or neglect during that period. You might also want to inquire if the car underwent any significant maintenance or repairs during that time.
The new clutch and flywheel are a plus, as it suggests the car has been taken care of, but you'll want to ensure that the installation was done properly, and check for any signs of premature wear in the transmission or clutch assembly. The fact that the brake parts were replaced is another good sign, as it means the previous owner likely maintained the car well.
In terms of the engine, the 2.7L engine in the 2007 Cayman is generally reliable, but be sure to check for any signs of oil consumption issues, as well as the condition of the water pump and the IMS bearing. While the 2.7 doesn’t have the same IMS issues as the 2.5L or 3.4L engines, it’s still worth having a mechanic check these out before purchase. You’ll also want to look for any signs of coolant leaks, as the cooling system in older Porsches can be prone to failure over time.
Make sure to have the car inspected by a Porsche specialist or trusted mechanic who knows the ins and outs of these cars. Look out for any signs of suspension wear, as parts like control arms can wear out over time, especially on a 2007. Also, check the tires—Caymans are known for being hard on their tires, so uneven wear could be a sign of alignment or suspension issues.
Overall, a 2007 Cayman with 58K miles for $25K is a reasonable deal, but thorough due diligence is key. If it’s in good mechanical shape and has been well-maintained, it could offer great performance and driving enjoyment.
