Oops? what did I do?
Good Evening everyone!
Long time Porsche drooler, first time buyer. I bought a 2008 Cayman 987.1 with about 108k miles on it from a non-Porsche dealership (but still German..lol) with a couple of things wrong with it. Needed sun visors. Need armrest. Not real show stoppers. Wife and daughter drive it home and wife says the tilt doesn't work. I fix it...finally. During the time I was fixing that, the battery decides to die on me. Completely. So i've tried almost everything that i have seen on the forums and YouTube for trying to start the car. I've got no power whatsoever. The key keeps getting stuck in the ignition. I did get it removed. The Fob Frunk button won't open it with it being hooked up to a battery jump pack (brand new NOCO). I've not removed the 18" tire as the special nut remover is in the Frunk. Another thing. My windows are down a little bit for some reason. Not sure this matters... Can someone explain what is going on and suggestions to fix it? Is this an anti-theft thing? Can i take out the Fob battery without having to go to a mechanic (dealership/indie shop) to get it programmed? Thinking maybe the battery in it might be low-however if the car battery is not powering anything I don't think a signal will get through to it to release the hood. Thanks! |
Do you have a battery or a jumper box instead of the noco? sometimes battery chargers wont kick in if it doesn't see a battery.
also some noco's have a manual override function you can try. Last edited by djnolan; 03-04-2025 at 05:16 PM.. |
Generally speaking, a jump box won’t work to power up the frunk release. Use a real battery and jumper cables, also making sure that the negative terminal is connected to a good ground point on the frame.
Thank you. Will try that!
I'm getting ready to try some of these suggestions but have another question (maybe few more)...
After I re-install the battery, will there be lights on the dash that need to be re-coded with I start it up? Thanks for the help!!!! |
sorry dj i forgot to answer you! I don't but am getting ready to go get one tomorrow. I did try the manual override a few times and it did not work at all.
Banned
Use a real battery and jumper cables.
