Eng / Trans Bolt Pattern Change ??
When did the bolt pattern between eng/trans change on our water cars? I am reading 02 to 03 model years? Is this correct? Does this mean no swap of later motors to earlier models with early trans, unless an adapter is used? Len :) |
Here is a 2006 Boxster 6 spd trans..... http://forums.pelicanparts.com/uploa...1746775512.jpg and here is a 2009 Boxster 6 spd Trans http://forums.pelicanparts.com/uploa...1746775627.jpg And here is a 2017 991 Turbo S Motor..... http://forums.pelicanparts.com/uploa...1746776423.jpg So the change in Bolt Pattern has come with the DFI Motor introduction in 2009. AND, note this motor now has a 10-Bolt Crankshaft.....earlier models have an 8-Bolt Crank. Len :) |
| All times are GMT -8. The time now is 08:10 AM. |
