![]() When did the bolt pattern between eng/trans change on our water cars? I am reading 02 to 03 model years? Is this correct? Does this mean no swap of later motors to earlier models with early trans, unless an adapter is used? Len
![]() Here is a 2006 Boxster 6 spd trans..... ![]() and here is a 2009 Boxster 6 spd Trans ![]() And here is a 2017 991 Turbo S Motor..... ![]() So the change in Bolt Pattern has come with the DFI Motor introduction in 2009. AND, note this motor now has a 10-Bolt Crankshaft.....earlier models have an 8-Bolt Crank. Len
