Disconnecting the battery
I have a true-flow air induction system sitting in my garage. It just consists of a drop in high flow filter and air-induction tube. I will install that someday but I noticed in the instructions they recammnend disconnecting the battery during instal to prevent CEL's I believe. Since the ECU is "adaptable," why would rebooting the ECU be necessary? Just wondering if you guys have heard of this.
03 3.2L 986 Guards Red/Black
-6 speed-
-Litronics-
-Carrera Light Wheels-
-Bose Sound-
-Painted Roll Bars-
Old 10-11-2005, 04:25 PM
AFJuvat's Avatar
If you introduce new values that vary significantly from the adaptive values, it can trigger a CEL.
Disconnecting the battery blows away the adaptation values and you start from factory baseline.
You don't "have" to disconnect the battery, it is just a common practice.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-12-2005, 10:40 AM
Zeke's Avatar
I didn't know rather to reply here or on the "radio code" thread, but I learned something today while replacing my battery. I powered the car thru the cigarette lighter with a spare, weak battery during the change out. Didn't loose a thing..........including my CEL which got triggered by a coolant issue, I believe. I also intalled a new 01 cap under the filler, so we'll see about the CEL resetting itself w/o me interupting the current for an hour.
Anyway, no re-doing the radio presets. I like it.
Old 10-21-2005, 09:43 PM
