-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Boxter engine issues timeframe (http://forums.pelicanparts.com/boxster-cayman-forum/180248-boxter-engine-issues-timeframe.html)
Eli K 08-30-2004 12:09 PM
Boxster engine issues timeframe
Hi all SmileWavy
My brother is looking to get his first Porsche, and from the way it looks it's going to be a Boxster!!!
He posed a question to me which I hope you can help answer.
I am aware of the MRS and other engine related problems during 1998-2001 years. Were boxsters plagued with the same issues in 1997 as well as post 2001?
Thanks for the help!
Zeke 08-30-2004 11:26 PM
Not so much and if it hasn't happened, it probably won't. Unless you found a car with extremely low mileage. '97 wasn't a real good year all around. New model syndrome. My '00 has been flawless except for the seat belt warning light staying on (very common and a dealer fix).
Eli K 08-31-2004 07:49 AM
Thanks Zeke. What would you classify as low milege? anything below 30-40K?
Zeke 08-31-2004 02:36 PM
Oh no. Under 10K. They're around. 30K and all problems should surface.
Tool Pants 08-31-2004 02:51 PM
I have a January 1997 Boxster and it does not have the seal issue. Any Boxster or 996 ever made can have the issue but it seems to be hit or miss.
Subject to a few differences the 2.5 1997-1999 are the same. In 2000 the 2.5 was increased to 2.7 and the 3.2 Boxster S came out. The top unit is better on those years but it is not hard to fix top issues with the 2.5.
Eli K 08-31-2004 07:36 PM
Thanks for re-asurance!
