-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Removal of coil-on-plug connection when replacing sparkplugs (http://forums.pelicanparts.com/boxster-cayman-forum/183249-removal-coil-plug-connection-when-replacing-sparkplugs.html)
k3eax 09-18-2004 08:10 AM
I have become extremely cautious when working with electrical connectors that I have not previously encountered; I have inadvertenlty destroyed several. I would welcome advise on the proceedure to used to discoonect the coil-on-plug connection on the Porsche Boxter and, by-the-way, an Audi A4 that also uses c.o.p.
Thanks!
Tool Pants 09-18-2004 08:34 AM
The connector is covered with a rubber boot. Slide the boot back to expose the connector. Then you will see a little lever on the connector you need to push while at the same time you pull the connector off the coil.
