Zeke's Avatar
Oil change
I can't believe the owners manual. I don't see anything on how to change the oil. OK, I'm a good enough mechanic to just go ahead and do it, but I always read instructions before doing something for the first time.
Anyone wanna run it down for me?
Oh, and I'm under there the other day just looking around. I couldn't believe how heavy that sucker was to jack up from the rear jack point. What a pig! I better get used to it I guess, but I've been so busy with the 914 construction for the last 13 mos., that I forgot how to work on street cars. My 914 weighs less than 2000 lbs. Whats the Boxster, 3000?
Old 02-03-2003, 05:39 PM
This is the way I do it. Jack up left rear so there is enough room for you to slide under. Remove filter housing with cup style oil filter wrench with 10 quart oil pan under it. Pull filter off motor and stick new one in place. Replace O-ring on housing, screw housing back on, and torque to 18 pounds. Slide pan over to under drain plug and remove with 8 mm allen and watch 9 quarts of oil come out very fast. I lower the car so that it is level when it is draining. Replace crush ring on plug and torque to 37 pounds. Jeff
Old 02-04-2003, 12:27 AM
Zeke's Avatar
Thanks, Jeff. Alot easier than a 911. I thought there would be a secondary tank or resevoir somewhere. Just curious, why the filter first?
Old 02-04-2003, 07:24 AM
Because you are not going to have an oil drain pan that is wide enough to catch the drips from the filer and drain plug at the same time as they are too far apart. Jeff
Old 02-04-2003, 08:31 AM
billfx's Avatar
My first oil change cost me $ 483.40 on my '01 BOX.@ 10,000 miles
Labor 345.00
filter insert 14.70
seal ring 0.34
oil 62.50
pollen filter 38.82
window cleaner 7.54
parts wash 3.95
ca. tax 10.55
serviced at The Auto Gallery, woodland hills, calif...
not very happy with the service dept.
will go to another dealer next time or just do it my self..
Old 02-06-2003, 02:15 PM
My oil change was $55, oil filter, 10 quarts of Mobil 1, and crush ring. But I have done all the work myself for 4 years as I have a 1997. In our local Boxster group we make the women change thier own oil. Jeff
Old 02-06-2003, 04:15 PM
boxster99's Avatar
Hello,
What weight Mobil do you recommend??
Thanks..Robert
Old 01-13-2005, 07:42 PM
This is an old one.
Mobil 1 0W-40 is on the current approved list. I use 15W-50 where I live, and this was on the approved list but removed several years ago.
Might ask your dealer what they use.
Old 01-13-2005, 08:27 PM
AFJuvat's Avatar
we use 15W50 on all cars 2002 or older
2003 and 2004 get 0W40
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-13-2005, 09:01 PM
What?
trj911's Avatar
Nice "how to" on the oil change Tool Pants! Thanks!
Tom J.
911SC Cab
SCWDP
CaymanS
Old 01-14-2005, 01:52 PM
boxster99's Avatar
Thanks you all for the reply on oil weight, 0-40 sounds like what I will go with!
Robert
Old 01-14-2005, 07:21 PM
cantdrv55's Avatar
Great write up Tool Pants. I'm tired of reading about how expensive an oil change costs for the Boxster because it is not DIYable.
Old 01-25-2005, 11:52 PM
Doug&Julie's Avatar
Oddly, I'm just a little turned on...
By the way, I think a Boxster is 2850 lbs. I think.
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 01-26-2005, 05:34 AM
AFJuvat's Avatar
Expensive? We charge about $120 for a boxster oil change - includes 10 quarts mobil-1 and filter\sealring.
It takes about 30 minutes. The longest part is waiting for the oil to drain out.
AFJuvat
Old 01-26-2005, 05:37 AM
