-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Particle Filter (http://forums.pelicanparts.com/boxster-cayman-forum/222545-particle-filter.html)
rjg1 05-21-2005 10:16 AM
Particle Filter
Hi All- New to Boxster world. Fantastic car 01 S. Have 2 questions- I purchased the box ' used. I have replaced the Carbon Particle filter in the front bay at the recommendation of other Porchephile. I discovered that removal is simply but I can understand if the filter has cover over it or not.Does the pleated filter just laid open to the the front compartment. Or should their be a cover to which it doest have now? 2nd,Have any here done their own 15/30 K services? It seem rather routine and yet dealer ask for 1K for the work?
Thanks In advance-
2002 BMW 1150Rs
2001 Boxster S
1998 Ford Expedition
joe and molly 05-21-2005 09:08 PM
Find an independent Porsche specialist. I've been quoted $385.00 for the 15K and $750.00 for the 30. A grand for the 15 is ridiculous.
Tool Pants 05-22-2005 04:14 AM
There is no cover for the filter, as you have seen.
Us local owners do our own service. I think the last was 60,000 miles.
rjg1 05-22-2005 12:39 PM
Thanks for the reply... Can you make a recommendation on a shop manual? Is Hayes still the way to go.?
FYI.. I had the two front wheels balanced on a Hunter 9700 Load balancer. ..It is worth every penny, $21 for each side. If you feel even a little vibration after the balancing job it NOT from the wheels/tires . Its that good... And it pays huge benefits on a Boxster with its directly wired to your brain steering feel.
Thanks Again Bob
Tool Pants 05-22-2005 03:17 PM
There is no aftermarket shop manual. The factory shop manual is very expensive and not much use for a DIYer. We started filming stuff and puting in on DVDs for this reason.
Bently has said for a few years that they might come out with a manual. They asked my mechanic friend at my local dealership to do it but he did not have the time. They must have found someone as he has been sent drafts.
