| Registered Join Date: Sep 2005
				1999 boxster engine blown , need help
			My engine blew at only 37K in my 1999 boxster.  After doing some research it seems this is fairly common event.  Any ideas on how to proceed with Porsche N.A. to get relief since my warrenty is out?  Certainly a Porsche engine shoud be able to go more than 37K!
|  09-01-2005, 10:11 AM |
| Registered Join Date: Aug 2001 Location: Brighton UK since 11/2012
			Get all the documentation for the service work, including the invoices and a report from the shop where the car is now and then contact Porsche NA Customer Relations... Make sure you note and document everything that is said and any phone conversations. And good luck.
				__________________ From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. | ||
|  09-01-2005, 04:38 PM |
| Registered |
			A poster named "Doug & Juile" had a similar thing happen. I think he purchased a new out of the box crate engine from Porsche for $7,000. It had a two year warranty, but sold it as it was a bitter memory.
				__________________ 1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect | ||
|  09-01-2005, 05:06 PM |
| Registered Join Date: May 2003 Location: The Beave, OR
				__________________ Doug Currently Between Porsches PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944 | ||
|  09-02-2005, 04:17 AM |
| Go Gators! |
			Might be time to look for that '99 996 3.4 to transplant.
				__________________ Timothy Stoops Air '62 356 B-‘86 911 Cab H2O '12 Cayenne | ||
|  09-07-2005, 05:08 PM |
| Registered Join Date: Mar 2005
			happened to mine too. I was suppose to have a 3.4L swapped in, but instead I went with a 3.2s w/ reprogrammed ECU. Runs really nice now, eh hem $12k later...  chances are, porsche won't help you unless you're a hardcore porsche owners club member and have owned porsches in the past. they kind of consider it a case-by-case basis. | ||
|  09-09-2005, 02:16 PM |
| Registered Join Date: Feb 2006
			The engine on my 99 Boxter w/ 50k+ miles also blew.  The Porsche dealer and Porsche Cars NA offered no financial compensation.  I am also looking for advice on how to proceed.
|  02-03-2006, 09:14 AM |
| Registered | Quote:
   http://www.986faq.com/10-0/default.asp Quote:
 3.4-3.6 conversions
				__________________ 1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 02-03-2006 at 09:32 AM.. | ||
|  02-03-2006, 09:24 AM |
| Registered Join Date: May 2004 Location: New Hampshire
				 |   It is pretty common to see the 98.5 through 99.5 Boxsters & early 99 Carreras have their engines fail. A total mfg responsibility for Porsche, but............. With complete documentation, the very best Porsche will do with these papers being waved in their face is to offer a replacement engine at a reduced ($7,000) cost. A used 996 3.4 motor can be bought for $4-5000, and it is not difficult to turn around the intake & swap the fuel lines over from the Boxster. So for that same $7k you could be driving a 300hp Boxster 3.4. The 00 - 01 3.4 engines are a good choice, as well as the smaller 00 & up Boxster engines. The 02 3.6 996C engine would be another option, but is too costly to install in a Boxster because of Vario-Cam Plus (BTDT). Its cheaper to fit a TTP twin turbo. We are looking forward to the next engine upgrade challenge, fitting a 3.6 or 3.8 S into the Cayman. The German tuners have done it, so we can too. Cheers, Len  Note: Thanks Todd for pointing out the info on the intake plenum. I corrected my error above. Len Last edited by BoxsterGT; 02-10-2006 at 01:40 PM.. | ||
|  02-07-2006, 05:36 PM |
				 | Quote:
 Although I did find out (too late) that a remanufactured Boxster S motor would have fit (with the 2.5 intake) for just a little bit more...which would have given me a motor with a warranty and 250 hp.
|  02-08-2006, 03:04 AM |
| Registered Join Date: Mar 2001 Location: Wallenstein, Ontario, Canada
			You don't want to swap the intake onto the 996 engine from a standard single plenum boxster, you are going to loose a lot of hp.  Maybe using the boxster S one would work ok but the stock 996 motor fits just fine.  The big cost on top of the motor when doing a 3.4 or 3.6 swap is 1) the DME reprogramming ~$1500 and the exhaust ~$2500-$4500 depending on  what you decide to do. The swap was 'realtively' cheap for me since I had a good engine with a TPC supercharger setup that I was able to sell to recover a lot of the cost. Also I was able to do it myself so labour wasn't an issue. Todd
				__________________ 1989 911 Targa | ||
|  02-09-2006, 08:44 AM |
				 |   How about a 300 mi 3.4 Cayman S motor with 295hp for your Boxster? I have a motor available now for anyone who needs one. Owner will likely take $7500 for it once his 997S 3.8 motor is installed. For questions email me at len@autosportengineering.com Cheers, Len   | ||
|  02-16-2006, 03:51 AM |
| Registered Join Date: Sep 2005 Location: IL
				 | Quote:
				__________________ 03 3.2L 986 Guards Red/Black -6 speed- -Litronics- -Carrera Light Wheels- -Bose Sound- -Painted Roll Bars- | ||
|  02-16-2006, 09:45 AM |
			They bolt up but they are too small,(ID too small and primaries are too short) how do you think on the 3.2L porsche only got 78 HP/L while the 3.4L stock gets 88 HP/L.  With a good exhaust and DME reprogramming you can get 95HP/L out of a 3.4. I ran the stock boxstter exhaust on my 3.4 while I waited for my headers/cats and muffler to arrive. Trust me you will loose a significant amount of power in a 3.4 if you run the stock exhaust Todd
|  02-16-2006, 10:58 AM |
| Registered Join Date: Jul 2005
			Do not mean to hijack thread-- has anybody got a Boxster engine that they want to sell-- cheap?
|  02-20-2006, 12:02 AM |
| Registered Join Date: Jan 2003 Location: Atlanta
			One of the best upgrades I have seen is the 3.8L 997S in the Boxster. I spent the afternoon driving one, yes a conversion in the USA.   I did the tuning on the car.. All I can say is wow.  Now I want a turbo 3.8L to sit in my garage. Anyone selling a Boxster with a blown or a high mileage engine?
				__________________ John | ||
|  02-24-2006, 04:40 PM |
			I have a new(never installed in a car)996 Turbo engine that is for sale. If someone wants to trade a Boxster engine( any model) plus some cash I would be interested. Will look at trading any Porsche engine for that matter. ( Please note-- not a swap-- I would want cash adjustment in my favour or interesting engine of equal value)
|  02-24-2006, 06:04 PM |
| Registered Join Date: Sep 2008 Location: Atlanta, GA
			Interested in the engine swap, I am also in Atlanta, have a boxter and want to upgrade, what is the easiest/cheapest path?
|  09-29-2008, 02:14 PM |
| Registered Join Date: May 2001 Location: hood river or.
				motor
			there is a motor for sale over on boxsterspec.com for 3500. 00 complete,sounds like a 99 motor. good luck
				__________________ 70e 911 99 boxster | ||
|  10-01-2008, 05:47 AM |
| Registered Join Date: May 2008 Location: Westchester, NY
|  10-05-2008, 05:44 PM |
