Intermittent white smoke @ startup. Oil level is @ 80%. 2000 s w/ 31000 miles. Last oil change 5 months & 2000 miles ago. Is this a cause for concern?
'00 Boxster S '05 Prius '88 Landcruiser |
Depends on how much smoke. A little puff that goes away quickly is no cause for concern and is considered normal.
Excessive smoke (fogging for mosquitos) indicates a failed oil\iair separator. Confirm by removing the oil fill cap with the engine running - if the vacuum tries to suck your hand into the oil tube, your separator is a goner. Not excessively difficult to replace yourself. The part is about $300 and you can replace it in a couple of hours, it is located at the rear of the engine, passenger side, top. AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
You can get the part for about $100-$150 (don't remember exactly) at http://www.sunsetporsche.com/porscheatcost.php
It took me about 1 1/2 hours to replace it from the top. |
