-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Two Questions (http://forums.pelicanparts.com/boxster-cayman-forum/248599-two-questions.html)
Ferrara_racing 10-30-2005 06:25 AM
Two Questions
Will storage of the Boxster and subsequent re-connection of the
battery effect an emissions test?
If you had a Boxster with 23K on the clock, and a good working clutch with the exception of grabbing high, would you change it now?
Thanks fellow owners,
AF
Porsche_Daddy 10-30-2005 09:02 AM
Why not leave the battery connected and use a battery maintainer that just plugs into the cig lighter? It seems to do the trick just fine.
Ferrara_racing 10-30-2005 02:37 PM
I will probably do that, I'd still like to know what the period of time, if any, would be needed between a battery disconnect and an emissions test.
Root_Werks 11-01-2005 01:17 PM
As long as your clutch grabs good, you should be okay. The fact it is high makes me think your pedal adjustment is off a little. usually a worn clutch will be low pedal and of course slip on a hard shift.
Ferrara_racing 11-02-2005 04:20 AM
Thanks for the reply, I was told the pedal cannot be adjusted. I'm going to do more research on this over the winter.
