Two Questions
Will storage of the Boxster and subsequent re-connection of the
battery effect an emissions test?
If you had a Boxster with 23K on the clock, and a good working clutch with the exception of grabbing high, would you change it now?
Thanks fellow owners,
AF
AJF
1998 Glacier White Boxster
1971 Fiat 124 Spyder
1999 Mercury Mountaineer
Old 10-30-2005, 06:25 AM
Why not leave the battery connected and use a battery maintainer that just plugs into the cig lighter? It seems to do the trick just fine.
03 3.2L 986 Guards Red/Black
-6 speed-
-Litronics-
-Carrera Light Wheels-
-Bose Sound-
-Painted Roll Bars-
Old 10-30-2005, 09:02 AM
I will probably do that, I'd still like to know what the period of time, if any, would be needed between a battery disconnect and an emissions test.
AJF
Old 10-30-2005, 02:37 PM
As long as your clutch grabs good, you should be okay. The fact it is high makes me think your pedal adjustment is off a little. usually a worn clutch will be low pedal and of course slip on a hard shift.
Old 11-01-2005, 01:17 PM
Thanks for the reply, I was told the pedal cannot be adjusted. I'm going to do more research on this over the winter.
AJF
Old 11-02-2005, 04:20 AM
