Tires bald again??
I have a 99 boxster with a 2002 boxster S engine, reprogrammed ecu, etc.. I'm on my third set of tires in 5 months.. I've never had to replace my front tires, but my rear tires go bald every two months.. I don't race at all, i drive about 500 miles a month.. Anyways, is this normal? I'm using 265 30 19... I usually buy inexpensive tires with a high UTG (hardness) rating- typically above 280.. Does anybody have any idea which tires i should try that are inexpensive and will last a while? thanks
Old 10-16-2005, 12:45 AM
AFJuvat's Avatar
Make sure your alignment is set corectly. You could have too much negative camber. Also, you are using 19 inch wheels - never really authorized on a boxster. I've noticed a tendancy for boxster rear wheels to toe out slightly when they are oversized, partucularly under acceleration.
Try yokohama AVS100.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-16-2005, 07:27 AM
Sounds like an allignment as AFJuvant said. When I first got my car I noticed the rears were wearing and the there was alot of negative camber. Is negative camber in the rear a normal thing for p-cars?
Old 10-21-2005, 12:32 PM
When the rear sags (due to age) or was lowered too much there is too much negative camber. Wheel alignment from new was rarely correct for US type roads; hence the front and rear tire wear. Reducing rear ngeative camber is a problem.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-22-2005, 12:07 PM
that's the odd thing- the camber on my car seems to be fine, i had my mechanic adjust the camber perfectly so that there was no uneven wear on the tires.. the rear tires go bald perfectly even (there isnt one side more worn down than the other)... it's just sad that tires with a 300 utg rating go in three months...
Old 10-25-2005, 06:32 PM
You sure you don't roast the tires at every stoplight? You go through tires like they are going out of style.
03 3.2L 986 Guards Red/Black
-6 speed-
-Litronics-
-Carrera Light Wheels-
-Bose Sound-
-Painted Roll Bars-
Old 10-25-2005, 07:12 PM
yea i know i do.. i've never even chirped the tires..
Old 10-26-2005, 01:31 AM
Eli at Pelican Parts's Avatar
My last set last over a year and that's with over 1K a month. Just replaced a set or rears only last month $650 wholesale not installed...... I would listen to AFJ on this one.......
-Eli
Old 11-29-2005, 11:28 AM
