Send a message via AIM to yarin
Bad O2 - ECU reset procedure
My mechanic told me which O2 is bad on my 2000 Boxster. He reset the check engine light. I changed the sensor. However he said there is some sequence that you have to follow in order to reset an internal code. Otherwise the car will fail the OBDII check. I found something here: http://www.systemsc.com/codes.htm
* Monitored & Set During Three Cycles; Warm-up, Driving, & Trip
Warm-up Cycle - SAI, EVAP, (from cold start to operating temperature, 2 min. minimum)
Driving Cycle - O2 Sensors/Heating, TWC, TRIM, (2 min. idle, 5 min. drive, 2 min. idle)
Trip Cycle - Diagnosis of All ECM Systems, (2nd Driving Cycle after shut-down, 20 min. max.).
Is this correct? Anyone have any luck with this procedure? I don't understand the exact sequence.... is it:
cold start 2min idle
2 min idle
5 min drive
2 min idle
shutdown
2min idle
5 min drive
2min idle
am i right? thanks!
'72 914
Old 05-21-2006, 04:12 PM
Car needs testing on a PST2 tester. Not always are O2 sensor faults caused by the sensor.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 05-21-2006, 06:20 PM
What is a PST2 tester?
'72 914
Old 05-21-2006, 06:36 PM
It's the Porsche tester for their products. it allows the vehicle to be diagnosed and systems read.
Old 05-22-2006, 12:47 PM
piwis is the newer tester used by the dealerships. pst2 was phased out
Old 06-04-2006, 01:34 PM
Most independant shops have the PST2..
Old 06-06-2006, 08:07 AM
