Kire's Avatar
Question Idle Control Valve?
I have a 2000 Boxster S that suffers from a ruff, unsteady idle. My mechanic believes it to be the Idle Control Valve or a vacuum leak. I have the complete set of factory books on this car and can't find any mention of a "Idle Control Valve" Is it referred to as something else in the shop manuals? I'd like to replace it myself if i just knew where it was at. Please , if anyone knows.....
Old 11-18-2006, 02:07 PM
AFJuvat's Avatar
It is called the IACV in the workshop manuals. It is located on the drivers side of the throttle body.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-18-2006, 05:20 PM
Kire's Avatar
Thanks, I found that, but it appears that there is not one on the Boxster S, Is this true? I have already cleaned the throttle body and made little difference, if at all. I believe all the vacuum lines are good because i had them replaced 2 months ago...
Old 11-20-2006, 12:28 PM
tholyoak's Avatar
If you have egas you don't have an Idle air valve only the cable TB cars do.
Todd
1989 911 Targa
Old 11-21-2006, 07:22 AM
