-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Speedometer change (http://forums.pelicanparts.com/boxster-cayman-forum/335719-speedometer-change.html)
danbmellow 03-14-2007 08:48 PM
Speedometer change
Great forum. Just purchased a 2002 Boxster S from Chicago and need to convert the speedometer to kilometers per hour. I found the threads on how to change the faceplate and the digital readout, but I need to know where to buy the kilometer per hour faceplate. Does anyone know of any aftermarket companies like "US Speedo" that offer a gauge kit with metric markings?
AFJuvat 03-19-2007 08:32 AM
You can try North Hollywood Speedometer.
AFJ
superglide 03-21-2007 12:02 PM
I've had good luck in the past with Palo Alto Speedometer, Palo Alto CA. www.paspeedo.com
Riskinator 03-27-2007 12:05 PM
Re: Speedometer change
Quick question. I'm buying a Cayman S and will be returning to Canada in about 18 months. I was told that I didn't need to change the speedometer as the digital readout one would suffice. Have you been told something different?
Thanks for your help.
danbmellow 03-27-2007 05:32 PM
The dealer here in Edmonton says you don't have to change the analogue gauge. Changing the digital readout is all that is required. I will be having the federal inspection done next week, if I find out differently, I will let you know. I just wanted it done for cosmetic reasons.
Riskinator 03-28-2007 08:26 AM
Hey thanks!
