Really cold natured
All of a sudden, my 98 Boxster is very cold natured when I first start it. The plugs have just been changed. It has a high pitched sound from the engine and after about 2 minutes, you can hear it go away. Like it winds down. After that it seems to run fine, not as powerful as new. Has a small backfire everynow and then. Also, Is there only 1 mass air flow sensor. I have taken the one out and cleaned it with CRC cleaner. Runs better for awhile. I may need one. It the one that Maxspeed sells for 139.00 any good. thanks.....
Old 10-28-2008, 07:11 AM
racer's Avatar
How many miles on the car? Where are you located (ie, how cold is it where you are?) Could be a belt slipping when cold.. could be signs of soon to be water pump failure.. Is the sound "metallic" in nature?
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 10-28-2008, 04:21 PM
Live in Florida...not cold weather...65,000...not metallic, sure about that.....just ordered a MAF...that should take care of it.............
Old 10-29-2008, 08:53 AM
