craig2148's Avatar
Window Problem
2003 Boxster: On the driver side door when I pull either inside or outside handle the window lowers about 1/2" as it should. When I release either handle the window goes up, which it shouldn't. I know that there is a microswitch inside the door, mounted to the handle, to identify when the door handle has been pulled. Is this switch at fault or is there another switch that recognizes when the door has been closed?
Craig
1999 Porsche Carrera
2003 Porsche Boxster
2003 Porsche Boxster S
Old 08-25-2009, 01:15 PM
BT911's Avatar
try the door latch
Old 08-26-2009, 12:43 PM
craig2148's Avatar
It was the door latch. Parts and labor $335 out the door.
Craig
Old 08-28-2009, 09:38 AM
