jjwood's Avatar
Leg Room + Center Console Question
After living with the tight squeeze between the steering wheel and the center console for four years, I'm looking for some relief for my 6'4" frame. Has anyone removed their center console in their 1st generation Boxster in search of more clearance? If you did, does it help?
Is there substantially more room in the interior of a second generation Boxster?
Thanks,
Jeremy
1971 911 Wide One 2.7
2012 911 Cabriolet
2011 Cayenne S
Old 12-22-2008, 09:10 AM
Aron in Toronto's Avatar
Yes many have removed the center console for more room.
Porsche sells parts to finish off the under dash area that covers the exposed wiring.
The kit is called "Carrara/Boxster GT3 console delete" or something similar.
Our host should have it.
Old 12-22-2008, 11:01 AM
Doug&Julie's Avatar
Kinda kills the best place to put a pair of shades, but I like the look. Now if someone would develop a small shelf right below the radio for those all important shades...
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 12-22-2008, 12:13 PM
I am 6'2" and did the GT3 console delete kit in our Boxster. Much more comfortable without the right shin making contact with the CD tray. Was about $100 and well worth it. Sunglasses can go in the door pocket, and the CD's go out the window with an iPod adapter.
Old 12-23-2008, 03:48 PM
Any number on that delete item? My local dealer cannt find it. Thanks for any help
Old 01-19-2009, 08:56 PM
From my packing list:
986-552-113-02-A10 Console Lining Black
986-552-241-02-A03 Trim Black
Pelican customer service should be able to help you get this ordered.
Old 01-20-2009, 03:37 AM
here is link to The racers group product for losing the console:
http://sfbay.craigslist.org/nby/pts/993864693.html
and for when the link expires:
Porsche 996 Console Delete Kit
Price: $100
For people with long legs that keep hitting the upper center console. It finishes off the front end when you remove the upper part of the console. Will fit ALL 986 Boxster's, and 996 Carrera's till 2004 and Turbo's till 2005. PN: 986.552.113.02.A10 List price is $135.72.
2000 Boxster Tiptronic
2005 Ducati M1000S
Old 01-21-2009, 06:20 AM
This is a great improvement. I'm only 5'9'' and didn't realize how much my leg was in contact with the console. Much more comfortable.
Old 03-07-2009, 08:14 PM
Would the kit work for 987?
Old 08-26-2009, 05:01 PM
racer's Avatar
Not 987 compatible... Different dash/console design. Plus, in the 986, for some years, the only thing you are removing is a tape/cd holder and storage bin. The 987 has other goodies in its center console if memory serves me correctly.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 08-26-2009, 07:27 PM
jwetering's Avatar
Can someone post some basic instructions for removing the console please? Thanks
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 09-26-2009, 09:45 PM
It was about 6 months ago that I did this conversion . If I remember right , you have to carefully pry off the carpeted and vinel sides of the center piece. This exposes the bolts that hold the whole thing together. I was able to pry them off with out braking them but if I remember right it felt like it took alot of force. There are two other bolt forward by the shifter. You should be able to see them once you get inside. Good luck.
Old 09-27-2009, 06:08 PM
jwetering's Avatar
xclnt - thanks.
jasper
Old 09-27-2009, 06:45 PM
