leaking anti freeze
Well Ive got a leak. It's appears to be from somewhere around the front of the engine. With the car running it's hard to tell where its comming from but the belt is wet and slinging anti freeze around.
Is this likely the water pump? How hard is it to replace if needed. The car is a 2000 S with 93,000 miles on it.
2000 Boxster S (gone) 1972 911s Targa (sold) 1971 911t coupe roller (sold) 1973 911t coupe / 3.2 (sold) Gruppe B #057 |
Haven't done one myself, but Wayne has a tech article up on it.
Pelican Technical Article: Water Pump & Thermostat Replacement - 986 Boxster (1997-04) - 987 Boxster (2005-08) |
Sounds like a waterpump.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Waterpump went out on my 2000 S @ 85,000 miles & it is very easy to change thru seat area. I did not catch the leak until pulley fell off at midnight on CA Freeway. Do yourself a favor change it now you are past due.
I recommend the low temp thermostat.
May as well replace serpantine belt and and rollers too..
I thought this could all be accessed by the panel behind the seats. not sure you need the car jacked up uber high...
