kx9862002's Avatar
Question Fuse replacement kit?
anyone knows the website link for purchasing fuse kit for 2002 boxster s?
having gone through Pelican but not sure which one is.
thx
sites I have found..
Pelican Parts.com - Fuses
Pelican Parts.com - Plug in Fuses
Pelican Parts.com - A.T.O. Mini Fuses
Pelican Parts.com - Maxi/Mini Fuses
Pelican Parts - Product Information: FUSE-BLT-KTN
Old 01-21-2011, 11:37 PM
kx9862002's Avatar
thx
Old 01-22-2011, 09:37 AM
kx9862002's Avatar
Wayne, do you know exact the fuse diagram for boxster s 2002?
Bentey manual says it's similar to 2001, but that'all it says, the book doesn't have diagram for 2002.
I did an "emergency unlocking from luggage front compartment lid", and I found that there were few fuses missing...
sadly, I didn't notice anything strange before.
Old 01-22-2011, 10:03 AM
Author of "101 Projects"
Wayne 962's Avatar
There should be a few fuses missing, as those are for optional equipment that are probably not installed. There should be a fuse chart pamphlet tucked on the inside of the door. Each year was slightly different from the previous year. I ordered one from Porsche when mine was missing - I'll have Scott put these in the catalog too. They are very useful.
If everything is working fine, then I wouldn't worry about the missing fuses - they are probably for SAT nav, or heated seats, or something like that.
-Wayne
Old 01-22-2011, 11:29 AM
kx9862002's Avatar
-Wayne
think i want to order one when the caralog is ready.
much appreciated.
Old 01-22-2011, 02:59 PM
Wayne 962's Avatar
Here's what I came up with for part numbers for this fuse booklet:
986-610-217-00 (1997 thru VIN 98VS6 01006)
986-610-217-01 (1997 from VIN 98VS6 01007)
996-610-217-01 (1998-1999 same as above)
996-610-217-02 (2000)
996-610-217-03 (2001 - superseded to 996-610-217-04)
996-610-217-04 (2002)
996-610-217-05 (2003-2004)
997-610-195-07 (2005-2008 - all previous versions have been superseded to the -07 part number)
If you wish to order one of these for your car (recommended), then simply punch the part number into our search engine located at the top of the screen.
-Wayne
Old 01-22-2011, 07:02 PM
Wayne 962's Avatar
Also, the appropriate Porsche part numbers for fuses are:
999-607-004-00 (5 amp)
999-607-083-00 (7.5 amp)
999-607-085-00 (15 amp)
999-607-087-00 (25 amp)
999-607-010-00 (30 amp)
996-610-214-00 fuse removal tool (seems to always to be missing).
-Wayne
Old 01-22-2011, 07:08 PM
kx9862002's Avatar
Here's what one of the booklets looks like (found one while cleaning up tonight).
I have already added the booklet into the cart.
but since your IMS retrofit product is going to be ready soon? (In Macth right?)
I think I will purchase them within 1 package till then.
Old 01-23-2011, 11:54 PM
