Outside temp not working correctly
The outside temp on my newly aquired 99 Boxster is not reading correctly. Any idea why? Maybe a new sensor?
Thanks Mike
Old 01-24-2011, 04:01 AM
Sensor is mounted in the front grill if you didn't know may be missing or out of position
Old 01-24-2011, 02:29 PM
s_wilwerding's Avatar
How far off is it? Does it change, or does it always read the same? If it changes, does it change in response to the temp (eg. is it always x degrees off)?
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 01-24-2011, 04:58 PM
It reads between 120 and 126 degrees F.
I didnt see any pictures in your article.
Mike
Old 01-25-2011, 05:37 AM
Apologies for the hijack, but is outside temp gauge an option? I have a 2004 and don't believe I have one and wish I did.
Old 01-25-2011, 08:22 AM
The outside temp display was part of the OBC option. You can tell a car that had a factory one by the lower left hand stalk on the steering column. But early cars you could get the temp display only portion of the OBC just by having the dealer enable it. Others have enabled some of the features by the use of switches often on the radio surround.
Old 01-25-2011, 09:30 AM
Sounds like the temp sensor itself is bad - it just unclips. At they mention in this thread, you might try to swap with a known good one, if you have a friend with a Boxster.
Steve Wilwerding
Old 01-25-2011, 09:59 AM
