-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Outside temp not working correctly (http://forums.pelicanparts.com/boxster-cayman-forum/587535-outside-temp-not-working-correctly.html)
Michael Everson 01-24-2011 04:01 AM
The outside temp on my newly aquired 99 Boxster is not reading correctly. Any idea why? Maybe a new sensor?
Thanks Mike
BYprodriver 01-24-2011 02:29 PM
Sensor is mounted in the front grill if you didn't know may be missing or out of position
s_wilwerding 01-24-2011 04:58 PM
How far off is it? Does it change, or does it always read the same? If it changes, does it change in response to the temp (eg. is it always x degrees off)?
Wayne 962 01-24-2011 10:09 PM
I've got an article on the front bumper that shows where this sensor is located, check it out here: Pelican Technical Article: Boxster Front Bumper Removal - 986 / 987
-Wayne
Michael Everson 01-25-2011 05:37 AM
It reads between 120 and 126 degrees F.
I didnt see any pictures in your article.
Mike
Jim Chambers 01-25-2011 08:22 AM
Apologies for the hijack, but is outside temp gauge an option? I have a 2004 and don't believe I have one and wish I did.
mikefocke 01-25-2011 09:30 AM
The outside temp display was part of the OBC option. You can tell a car that had a factory one by the lower left hand stalk on the steering column. But early cars you could get the temp display only portion of the OBC just by having the dealer enable it. Others have enabled some of the features by the use of switches often on the radio surround.
s_wilwerding 01-25-2011 09:59 AM
Sounds like the temp sensor itself is bad - it just unclips. At they mention in this thread, you might try to swap with a known good one, if you have a friend with a Boxster.
Wayne 962 01-25-2011 03:40 PM
Mike
See the inset of Photo 1.
-Wayne
