rcarpen22's Avatar
new strange noise
I searched but couldn't find an instance of this. When cold, right after I start the car I hear a kind of grinding noise. It sounds like maybe the starter doesn't disengage fast enough and grinds on the way out. Once the car is hot it won't do it on re-start. Anyone heard this noise before? Is it impending doom of some sort?
Old 01-27-2011, 07:30 PM
rcarpen22's Avatar
Oh, on a more pleasant note, I put new tires on the back of the car today. It is much quieter and rides a little better. The fronts were still in good shape but the backs were shot.
Old 01-27-2011, 07:32 PM
rcarpen22's Avatar
Yeah, I guess it could be chains. Dang it. I was hoping to at least drive the thing a little bit before i have to ship it off again. You think it's safe to crank it up one more time just to get it on the trailer? It was running like a champ yesterday and cranked right up with no noise after it was hot. So, it hasn't jumped timing or done anything too sinister yet.
Old 01-28-2011, 05:22 AM
harryrcb's Avatar
Do you really want to take that chance? I would ask a couple of friends over for beer and (important) "before" consuming the beer ,push the car on the trailer. JMO
Crazy Austrian
http://www.ws-ab.com
Old 01-28-2011, 06:12 AM
JFP in PA's Avatar
It can also be the starter Bendix drive not disengaging properly, which only requires cleaning the drive and lubrication..................this is a common and re-occurring problem on these cars.
Accrochez-vous bien de vos rêves..........."
Old 01-28-2011, 06:19 AM
rcarpen22's Avatar
See, that's what I thought it was, because that's exactly what it sounds like, and it happens right after you crank the car, and only when cold. If that is a common problem with Boxsters, then that makes me like 95% sure that's what it is. Part of me wants to just get the IMS done for piece of mind though. Thanks for the replies.
Old 01-28-2011, 07:26 AM
JFP in PA's Avatar
We get them in from time to time; pull the starter, clean the Bendix with PB Blaster or similar, lube the unit with some DuPont spray Teflon (won’t pick up water or dirt), reinstall starter. Miller time………….
Old 01-28-2011, 07:51 AM
rcarpen22's Avatar
Yep, I think I'll try that. My concern was that it would do bad things to the expensive dual mass flywheel. I hope pulling the starter is in 101 Projects! :-)
Old 01-28-2011, 09:10 AM
JFP in PA's Avatar
Starter replacement is a common, and pretty straight forward affair, your only difference is after servicing, you are putting the old one back........
Pelican Technical Article: Boxster Starter Replacement - 986 / 987
Old 01-28-2011, 09:40 AM
