Cutoff Switch
I have a 1999 Boxster. I would like to install a cutoff toggle switch. The instructions that I received with it is to splice into the ignition coil. It doesn't
say which one. All the spark plugs have one. I am a little leary about cutting a wire on a coil. Which coil do I connect this to? or is there another location (wire, fuse, etc) that I can make the connection? Is the cutoff switch neccessary or am I paranoid? |
Adding a cut off switch to one coil will only shut off one cylinder, not what I think you are trying to do. You would be better off to locate the fuel pump power wire and put it there, that would prevent the car from starting...............
Accrochez-vous bien de vos r๊ves..........." |
What are you trying to prevent? I've never seen a Boxster owner who felt it necessary to install such a switch and I see many much more expensive cars without them.
As Mike stated, what are you trying to accomplish? Cut-off switches are used to cut the positive battery lead, typically in a track car application. Cutting power on a street car will cause numerous issues with the car's computer system and would not be recommended.
'73 911 Frank 'n Meanie 2002 Boxster S PCA Instructor Circa '95 |
Author of "101 Projects"
If you want to cut off the fuel pump, then I would recommend tapping into and interrupting the flow to the fuel pump relay. Instructions can be gleaned from my article here: Pelican Technical Article: Boxster Fuel Pump Replacement - 986 / 987
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I think he is after a cheap anti theft device to prevent the car from starting........
-Wayne
