yamatodog (guest)
Guest
Posts: n/a
to swap a 2002 3.6l motor into my 2001 box. is a NEW 7.8dme reqd. or can I use the one that came from the 3.6l doner car?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Engine Conversion Project - 986 Boxster (1997-04) - 987 Boxster (2005-08)
Old 03-19-2011, 10:35 PM
Author of "101 Projects"
Wayne 962's Avatar
You don't need a brand new 7.8 DME, but if you use someone elses, then you need to make sure that you get the immobilizer, and the keys from the donor car. This is because the DME and the immobilizer are keyed together. You can always get replacement keys to be cut and reprogrammed to work with the ECU, but most of the time it's just easier to get the electronic key portion from the donor car. If you don't get the immobilizer from the donor car, then you will have to purchase a brand new one and program the DME to work with that one.
- Wayne
