Need part!!!
Can anyone help me? Need Driver Side Window Regulator for 97 Boxster (not new) or reasonably priced! Email me at - tlynncarlini@aol.com. Thanks
Author of "101 Projects"
The problem with buying a used regulator is that it is impossible to know if they are worn internally or not. I had a lot of trouble with my regulator not lowering the window down the few millimeters or so when you open the door. I tried adjusting the heck out of that thing, and it wouldn't work. Finally, I just replaced the regulator, thinking that it may be worn internally. That did the trick. So, used ones may work for lowering the window down using the switch, but if they have too much slop in them, then they may not properly lower your window down that little bit when you open the door.
I would just buy a new one to be sure. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Boxter Window Regulator
Thanks Wayne for information & advice. Can you give me price on new left (drivers side) window regulator? I difinitely will not buy used one with the information you gave me. Thanks again, Teresa
I'll have Glenn in sales get in contact with you on Monday.
Thx, Wayne
Hi Teresa, I just sent you an email. Thanks
Glenn Sager Pelican Parts Sales Team 310 626-8765 x240 glenn@pelicanparts.com '78 911SC Targa, '73 914 2.0, '16 991S, '24 Macan |
