Radio won't come out - wrong keys (pic)
Boxster S 2002, Becker CDR 22
bought these to pull it out but they simply pull straight out again, doesn't matter which way I put them in.. Have I got the wrong ones ?? I have removed the heater module and the Radio will pull out about a half inch but it'll do that with no keys inserted.. aaarghh
Old 04-11-2011, 12:48 PM
Schumi's Avatar
I believe the keys should look like these:
M
Old 04-11-2011, 01:10 PM
Thanks Schumi..looks like i got sent the wrong ones..hence my utter frustration
Old 04-11-2011, 02:05 PM
If you drop into just about any place that does car stereo installations, I'm sure if you talked nice they'd pop the radio out for free.
Old 04-11-2011, 03:30 PM
Author of "101 Projects"
Wayne 962's Avatar
The 2nd pic is correct. You don't need the keys to remove the radio, but they do help. If you have something that approximate width, you can stick it in there to release the catches, and then sometimes you can wiggle the radio out. Doesn't always work, but I've managed to get it done when I couldn't find the my key set.
-Wayne
Old 04-11-2011, 10:18 PM
