Question Need help with engien swap!
Ok I have a late 1998 Boxster with 2.5 (bad)
I have a 2000 2.7 complete with gearbox and DME (good)
I realize the 2.5 is throttle cable and the 2.7 is EGAS
Question one Wayne's book and several posts talk about using a throttle cable TB either adapt the 2.5 or use a 3.4...
Ok I get the make the cross over pipes fit but how do you accommodate the electrical connectors??? The 2.5 has 2 3 pin connectors one is the TPS the other idle control
The 2.7 harness and TB have one 6 pin connector...
Clearly I need to build an adapter but not sure how or what wires...
OR...
I bought a throttle pedal position sensor from a 2001 - think I could make the 1998 cable work that but still need to figure out how to wire that into the 2.7 harness - I suspect in a 2000 these signals go back an into the engine harness at the trunk...
Can any who have actually done a swap help me with how do you deal with egas?
Rich
Old 12-03-2013, 01:44 PM
Tags
engine swap
