RichD (guest)
Guest
Posts: n/a
Ok I have a 1998 with a dead 2.5 Liter.
I have a full 2000 2.7 Liter with gear box and DME.
Dropped the old one out -
I realize I need to use the mechanical throttle cable Throttle Body - and I see and understand the mechanical challenge of the crossover tube size difference...
two questions - if I do use the 2.5 Throttle body on the 2.7 how do I wire the connectors? the 2.7 has one 6 pin connector the 2.5 has two 3 pin connectors... Maybe this can't work I'm not sure
2 I've also heard get a 996 3.4 Throttle Body - does that solve both the size and connector issues? Can anyone give me a good part number for that?
I'd rather use the 2.5 Throttle Body and get the project done - right now I'm not installing the 2.7 until I get this sorted out - easier to solve when not in the car...
All advice GREATLY appreciated!
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-21-2013, 04:47 AM
Nick at Pelican Parts's Avatar
I would stick to using the throttle for the engine. Otherwise you will be trouble shooting compatibility issues. With the 6 wire, it has motor control wires and 4 TPS wires. I think you will want to get a harness for the 2.7 if you don't have it.
Give our parts specialists a call at 1-888-280-7799. They can help you with the part numbers.
- Nick
need more info!
Nick,
How do you use the TB that comes with the engine?
The 1998 is throttle cable and the 2.7 is EGAS
I think I could use a 2000 throttle pedal position sensor and wire back to the 2.7 harness but HOW???
For those that have done a swap what the trick???
Old 12-03-2013, 01:50 PM
