rluciano's Avatar
Clutch recommendations
Hi. First post in the Boxster forum. I actually have a Ruf 3600S. Boxster S tranny and 3.6ltr 996 engine with X51 package, etc. The clutch is on the way out. Ruf thinks that I have a standard 996 clutch and dual mass flywheel. The clutch has always felt heavy to me. Brand new it was much heavier than a 944, a '93 BMW M5, or even an '83 911SC.
What clutch / flywheel combo will hold up to ~400hp and maybe give me a lighter feel than before?
Thanks,
Richard
Original owner 1986 944
1987 951 968 wing from CPR, Deutsche Nine headlights, KW Variant 3s, Lindsey Stage 2 intercooler, Big Reds
2003 Ruf 3600S S-Car-Go equal length headers, otherwise almost stock
72 911T w/ SC 3.3SS engine MoTeC Hargett ITBs
Old 05-29-2011, 07:53 PM
Author of "101 Projects"
Wayne 962's Avatar
You don't have many options on going "softer". You can run a puck racing clutch and that will get heavier. You do probably have a 996 clutch in there, *or* someone may have put in a higher performance package along the way. I would try the stock 996 setup (it should work with that engine and tranny combo) and see if that improves your ride.
-Wayne
Old 05-30-2011, 10:33 AM
rluciano's Avatar
I bought the car new straight from Ruf in Germany but their record-keeping or maybe willingness to share the records is very limited. The clutch has always been heavy.
Is there maybe a different clutch master cylinder that I can switch to. I believe I'm stuck with the slave cylinder that comes with the tranny. Thanks for all your help.
Old 05-30-2011, 11:17 AM
