how many miles on your boxster with no IMS upgrade
Just curious to see how many miles people have on their boxsters with NO IMS Upgrade
Old 03-14-2011, 09:21 AM
Zeke's Avatar
55k
Old 03-14-2011, 09:28 AM
98 986 95.6k still going strong with no issues.
Old 03-14-2011, 09:30 AM
nosnow4pc's Avatar
141,000 with scheduled maintenance by Porsche, Oil changed at 8-10K intervals. I will be replacing when doing my clutch next month.
99 Boxster 5-speed
12 Acura TSX 6-speed
Old 03-14-2011, 10:22 AM
River Rat
Dave 86 930 Fl's Avatar
IMS Failure
I saw one @ the Porsche dealership this morning w/IMS failure, not pretty.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 03-14-2011, 10:32 AM
JMatta's Avatar
Nine years and 19k miles...installed LN low temp t-stat and will replace original water pump this spring (per Raby recommendation). Am considering my friend (who does 911 engine rebuilds) to replace my IMS, just for peace of mind. I feel fortunate because Charles Navarro is a member of Chicago Region PCA, very willing to give good advice and really supports the PCA community.
'73 911 Frank 'n Meanie
2002 Boxster S
PCA Instructor Circa '95
Old 03-14-2011, 02:43 PM
2000 S. 23000 miles. No issues.
Old 03-14-2011, 07:35 PM
98Tip w/68K
Old 03-15-2011, 01:30 AM
103k miles on a 2000 S. Not a highly maintained car.
Old 03-15-2011, 07:47 AM
1999 with 90K miles.
1999 996 C2 sold - bought back - sold for more
1997 Boxster BSR POC/PCA #254
1978 911 SC Daily Driver
Licensed DE/TT Instructor
Old 03-15-2011, 09:31 PM
ronster's Avatar
84K on my '99 Tip when I had the IMS replaced. Bearing looked ok but seal was gone, smelled burned and felt a little loose. Haven't heard back from LN as to it's condition but I feel like I got to it just in time.
Old 03-15-2011, 09:36 PM
48K before LN IMS is installed.
Bearing looked good with small amount of play.
Old 03-16-2011, 10:08 AM
2000S removed engine at 88,500 miles for rebuild, IMS bearing shaft had 1/4" movement side to side. I estimate that double row bearing would have failed within 4k miles.
2001 3.2 just disassembled for rebuild same mileage as above engine, IMS bearing seemed like new. That IMS is at LN for bearing upgrade now.
Old 03-16-2011, 12:40 PM
76,000 on my 1998 986.
I bought it with 67,000 miles and am the 5TH owner but had maint. records that showed oil changes at 5-7,000 miles!
I will continue to change the oil every 5,000+
1976 912E (#2037)
1998 Boxster 986
Old 03-16-2011, 01:56 PM
Jwade
20,850 and no issues on my '01 S. If it blows it blows...then let the 3.6 fun begin.
Old 03-17-2011, 04:40 AM
2000 S with tip, 96,000 miles.
Oil change's around 5,000 miles.
2000 Boxster S (gone)
1972 911s Targa (sold)
1971 911t coupe roller (sold)
1973 911t coupe / 3.2 (sold)
Gruppe B #057
Old 03-17-2011, 05:04 AM
I changed mine for the LN bearing at 84k. Bearing was good but seal was not. I'm glad I changed it when I did.
2000 2.7L
Old 03-17-2011, 06:42 AM
99 986 94K miles no problems yet..
Old 03-17-2011, 06:58 AM
Why would you
send an IMS to LN for "bearing upgrade" from a 2001S? Was it a replacement engine from the '03-'04 era where the entire shaft has to be replaced?
Old 03-17-2011, 08:31 AM
