how many miles on your boxster with no IMS upgrade
Just curious to see how many miles people have on their boxsters with NO IMS Upgrade
55k
98 986 95.6k still going strong with no issues.
Author of "101 Projects"
1999 986 Tip w/ 80K
2000 986 manual w/ 1K on new Porsche crate motor 2001 996 manual w/24K 1999 996 manual w/31K, IMS blew up at 30K -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
141,000 with scheduled maintenance by Porsche, Oil changed at 8-10K intervals. I will be replacing when doing my clutch next month.
99 Boxster 5-speed 12 Acura TSX 6-speed |
River Rat
IMS Failure
I saw one @ the Porsche dealership this morning w/IMS failure, not pretty.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs. |
Nine years and 19k miles...installed LN low temp t-stat and will replace original water pump this spring (per Raby recommendation). Am considering my friend (who does 911 engine rebuilds) to replace my IMS, just for peace of mind. I feel fortunate because Charles Navarro is a member of Chicago Region PCA, very willing to give good advice and really supports the PCA community.
'73 911 Frank 'n Meanie 2002 Boxster S PCA Instructor Circa '95 |
2000 S. 23000 miles. No issues.
98Tip w/68K
103k miles on a 2000 S. Not a highly maintained car.
1999 with 90K miles.
1999 996 C2 sold - bought back - sold for more 1997 Boxster BSR POC/PCA #254 1978 911 SC Daily Driver Licensed DE/TT Instructor |
84K on my '99 Tip when I had the IMS replaced. Bearing looked ok but seal was gone, smelled burned and felt a little loose. Haven't heard back from LN as to it's condition but I feel like I got to it just in time.
48K before LN IMS is installed.
Bearing looked good with small amount of play. |
2000S removed engine at 88,500 miles for rebuild, IMS bearing shaft had 1/4" movement side to side. I estimate that double row bearing would have failed within 4k miles.
2001 3.2 just disassembled for rebuild same mileage as above engine, IMS bearing seemed like new. That IMS is at LN for bearing upgrade now. |
76,000 on my 1998 986.
I bought it with 67,000 miles and am the 5TH owner but had maint. records that showed oil changes at 5-7,000 miles! I will continue to change the oil every 5,000+
1976 912E (#2037) 1998 Boxster 986 |
Jwade
20,850 and no issues on my '01 S. If it blows it blows...then let the 3.6 fun begin.
2000 S with tip, 96,000 miles.
Oil change's around 5,000 miles.
2000 Boxster S (gone) 1972 911s Targa (sold) 1971 911t coupe roller (sold) 1973 911t coupe / 3.2 (sold) Gruppe B #057 |
I changed mine for the LN bearing at 84k. Bearing was good but seal was not. I'm glad I changed it when I did.
Steve 2000 2.7L |
99 986 94K miles no problems yet..
Why would you
