Send a message via MSN to kzsport
Smile Need help for 08' Cayman S timing
Hi
I'm new in this forum.
I want to know the timing check procedure of 08' Cayman S(M97.21).
Is this timing check procedures the same with 986??
If not,what different of assembly engine detail in these 2 vehicles??
Will very Gratitude for any advice.
Brian
Old 07-08-2011, 01:24 PM
s_wilwerding's Avatar
I'd say if you're doing cam timing (which is I assume what you're talking about), it would probably be best to pick up a Cayman factory manual. My guess is that the Boxster manual of the same vintage would work, but if it were my engine, I'd get the Cayman manual.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 07-08-2011, 01:41 PM
Yes,
I'd like to engine assembling due to burn 1st connect rod bearing and crankshaft on 08' cayman s.
Just want to make sure correctly manual I had.
Of course.marked all bolta,items while disassembling and storaged well.
Will start this project on tmr...
Old 07-09-2011, 11:50 AM
