Intermittent Starting Problem
I'm a little stumped on this one. I have an 02 S with 99k miles on it that has a strange starting issue. Sometimes when I turn the key to start, nothing happens. If I try a few more times, usually releasing and re-pressing the clutch pedal and sometimes taking the key out and starting all over, it starts. So when I say nothing happens, I mean the starter isn't cranking at all (but all dash panel lights, oil measurement, etc kicks on every time).
The ignition switch was pretty shot when I bought the car a few months back (had to manually turn it back from start to run every time or else the wipers wouldn't work, etc) so I figured that was it. Recently replaced it with a new one (electrical part only) but the problem still happens every once-in-a-while.
Any ideas? The only two things I can think of it could be are: 1) Clutch pedal switch, or 2) A problem reading the chip in the key.
As a side note, my cruise control also intermittently doesn't work (i.e. won't turn on at all... the dash light works just fine but often if I hit the on/off it does nothing). I mention that only because I know the clutch switch plays into the cruise control (but my understanding is that it's a different switch).
Thanks!
Old 08-25-2011, 08:15 AM
1986 Targa 1972 RS clone
magnuskgc's Avatar
me too
bump for having the same issue..... anybody have any ideas??
Old 03-19-2012, 01:42 PM
ronster's Avatar
Bad ground connection somewhere? Have you checked you battery lately to make certain the connections are solid? Also it could possibly be a short in the disabling module under the driver's seat or a bad switch under the clutch. Those are all my ideas.
Old 03-19-2012, 02:21 PM
I had to replace an ignition switch in a honda one time.
It worked okay for a few weeks until one day it wouldn't start again.
Had to take it apart and found that the wiring harness needed to be pushed in a little further to get a better connection.
Old 03-19-2012, 02:25 PM
2001 Boxter S
A friend of mine had the same issue 6 month ago on his 99 box.
I replaced the clutch switch for him. 23$ (if I remember correctly) and 10 minutes under the dash. Works great since.
Old 03-19-2012, 06:00 PM
I think it is very likely to be the clutch switch. This is an easy fix. This switch sees a lot of work and they fail relatively often.
Old 03-19-2012, 06:56 PM
mmari270's Avatar
Same issue, 86 carrera??
Old 11-22-2012, 03:57 PM
mmari270's Avatar
Was convinced it was the electrical portion of the ignition, not so sure now..
Old 11-22-2012, 03:59 PM
