-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Pulsed Injection or Continuous Injection (http://forums.pelicanparts.com/boxster-cayman-forum/627308-pulsed-injection-continuous-injection.html)
newlife 08-30-2011 11:31 AM
Hi,
I have a 2000 S Boxter, in Southern California.... does anyone know if my Porsche is Pulsed Injected or Continuous Injected ?
Rod
very~worn~944 08-30-2011 11:38 AM
Sequential pulse
newlife 08-30-2011 12:12 PM
so would that be Pulsed Injected... ? I'm reading a Bosch Fuel Injected Engine Management book and they talk about Pulsed and Continuous, not Sequential...
Rod
newlife 08-30-2011 12:16 PM
Okay just found something on Sequential. Motronic ?
rod
seventythree 08-30-2011 02:37 PM
On a Continuous Injection System (CIS), injectors have no moving parts, hence, no electrical wires connected to them.
Zeke 08-31-2011 09:44 AM
Rod
You're reading about the CIS, or Constant Injection from the 2.7 and 3.0 911 days. Since '83 it's been Motronic electronic injection. Some do call it sequential, but that is the obvious point. Some manufacturers called it multi-port injection. Again, pretty obvious but CIS was also multi port.
So you end up with redundant names like multi port sequential (pulsed) electronic fuel injection. All cars since around 1990 have electronically injected motors.
newlife 08-31-2011 10:10 AM
Thanks Milt !
Rod
very~worn~944 08-31-2011 10:38 PM
Just to clarify the need for "sequential". Porsche has also used "batch fire" systems in the 944's, pulsing all of the injectors together.
newlife 09-01-2011 10:52 AM
Thanks for the reply !
Rod
