Reuse 2.5 rod bolts?
I am rebuilding a 986 engine and am wondering if the rod bolts can be reused or do they stretch when torqued. I started a blog titled "1998 986 rebuild" with pics if anyone's interested. I work on it in my spare time so there will be some time between entries.
Old 10-02-2011, 04:51 PM
EBS_Don's Avatar
Absolutely do not re-use these. There have been supercessions on this part along with a torque value change. Going with ARP's is an even better idea. It's not a good idea to re-use the original early head bolts either. Again, superceded to much better part.
Don Weaver-EBS Racing
don@ebsracing.com
2006 Cayman S
'86 944T
'00 Boxster with EBS Racing 3.4 liter engine
Old 10-02-2011, 08:08 PM
Thanks Don, glad I asked.
Old 10-03-2011, 06:23 AM
torque specs ?
I'm also doing a rebuild of a 2.7L 986. Can anyone tell me the bolt torque specs for the rod bearings, crankshaft carrier bolts (Main Bearing Bolts) & the engine case bolts ?
Old 01-26-2012, 05:09 PM
závodník 'X'
intakexhaust's Avatar
Are you seriously doing a rebuild without a workshop book? Yikes!
Old 01-29-2012, 10:40 PM
harryrcb's Avatar
here you go
Crazy Austrian
http://www.ws-ab.com
Old 01-30-2012, 08:35 PM
Thanks!
Old 05-06-2012, 02:36 PM
I don't think you can just replace the bolts if you replace the bolts you have to resize.
Old 05-06-2012, 05:44 PM
The Porsche connecting rods cannot be resized since they are the cracked beam design. You can replace the rod bolts & ARP bolts are highly recommended.
Old 05-06-2012, 08:24 PM
I was wondering about that.
Old 05-06-2012, 08:33 PM
