franco (guest)
Guest
Posts: n/a
I have 1999 boxster monday the engine light came on and the car died.I had it towed home and it will start, but it will
not run properly. It makes loud noises, Have any idea.
It's been running perfect for around 14 months. No warning at
all. No oil leaks.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Air / Oil Separator Replacement - 986 / 987
Old 11-08-2011, 04:36 PM
Author of "101 Projects"
Wayne 962's Avatar
You need to check the fuel injection trouble codes using a code reader. Check out our article on the subject (in the tech articles section). Without knowing this information, you're just guessing blindly.
- Wayne
harryrcb's Avatar
[QUOTE=franco (guest);6359953]I have 1999 boxster monday the engine light came on and the car died.I had it towed home and it will start, but it will
all. No oil leaks.
If it's making loud noised you don't want to be starting it. you will just make matters worse. Loud noise would indicate something broke internally.
Crazy Austrian
http://www.ws-ab.com
Old 11-09-2011, 09:12 PM
