Is there any way to depress the lock pin in figure 3 step D without having a key? I know you need the key to release the locking assembly but is there any way around this?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Ignition Switch Replacement - 986 / 987 |
I think that you can remove the entire ignition switch assembly without the key (Figure 4), but not the key assembly itself. At that point, you'd have to probably replace the whole mechanism.
- Wayne |
| All times are GMT -8. The time now is 09:58 PM. |
