Tony (guest)
Guest
Posts: n/a
Is there any way to depress the lock pin in figure 3 step D without having a key? I know you need the key to release the locking assembly but is there any way around this?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Ignition Switch Replacement - 986 / 987
Old 11-12-2011, 10:15 PM
Author of "101 Projects"
Wayne 962's Avatar
I think that you can remove the entire ignition switch assembly without the key (Figure 4), but not the key assembly itself. At that point, you'd have to probably replace the whole mechanism.
- Wayne
