Guest
Posts: n/a
I have a 2000 Boxster which has the newer electronic throttle built into the throttle body. I'm getting a ODBII code PO507 that is telling me the Idle Air Cotrol is bad. Based on this article I don't think my car has an IAC? Can you clarify? Idle is eratic and check engine light is blinking.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Throttle Body Replacement / Cleaning Intake & Boots - 986 / 987 |
Author of "101 Projects"
On cars with the electronic throttle body, the idle air is controlled by the computer opening and closing the throttle slightly. So, there may be an issue with the actual unit, or it may be that it's dirty or clogged. I would clean it first (see the article in our tech articles section on this) and see if that improves the performance. I suspect it will. Also, if it's really dirty or clogged up, keep in mind that this is unusual, and that something odd must be causing the clog. It might be a bad air filter, or a failing air-oil separator.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
